Api session event editor parametric set plot function
Revision as of 12:13, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Plot Function
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Design
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Plot
2 REQUIRED (FUNCTION Integer ID or multiple values in array [1, 2, 3]) Function
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorparametric/set_plot_function/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ 1, 2, 3 ] ]
