Api session event editor panel add answer
Revision as of 12:13, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add Answer (Panel)
0 REQUIRED (PANEL Integer ID) Panel
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/add_answer/?f=JSON&token=API_TOKEN
with content:
[ 93 ]
