Api session event editor overlay set key value
Revision as of 12:12, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Change a key for a specified Overlay. The Overlay must be an Overlay which makes use of keys to read attributes of geographical items, as input for its calculation.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a grid Overlay)
1 REQUIRED (String) Key name
2 REQUIRED (String) Attribute to look for
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_key_value/?f=JSON&token=API_TOKEN
with content:
[ 31, "Key name", "Attribute to look for" ]
