Api session event editor overlay add result child
Revision as of 12:12, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add a specified result type as a child Overlay to a specified grid Overlay. The child Overlay's result will be based on the parent's calculation, allowing you to get multiple types of results from the same calculation.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a grid Overlay with result types)
1 REQUIRED (String) Result type for new child Overlay (must be a valid result for the parent Overlay type)
200 Integer (Overlay ID)
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/add_result_child/?f=JSON&token=API_TOKEN
with content:
[ 52, "Result type for new child Overlay" ]
