Api session event editor parametric set plot attributes
API Event to Set Plot Attributes
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) | Parametric Design | |
| 1 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Plot | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Attribute name | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | Attribute Values | |
| 4 | OPTIONAL | (Integer number) | Source (optional) |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorparametric/set_plot_attributes/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ "Attribute name 1", "Attribute name 2", "Attribute name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], "" ]
