Api session event editor parametric remove plot attributes
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Plot Attributes
0 REQUIRED (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) Parametric Design
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Plot
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute name
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorparametric/remove_plot_attributes/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ "Attribute name 1", "Attribute name 2", "Attribute name 3" ] ]
