Api session event editor parametric apply
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Apply
0 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Design
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
2 REQUIRED (FunctionType or multiple values in array [a, b, c]) FunctionType[]
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
4 REQUIRED (MultiPolygon or multiple values in array [a, b, c]) MultiPolygon[][]
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorparametric/apply/?f=JSON&token=API_TOKEN
with content:
[ 10, 36, [ "BUILDING", "SIDEWALK", "GARDEN" ], [ 1, 2, 3 ], [ [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799369.134454882 ], [ 658745.5042595589, 6799369.134454882 ], [ 658745.5042595589, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799381.908148949 ], [ 658789.3039617377, 6799381.908148949 ], [ 658789.3039617377, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799337.1345314 ], [ 658700.9736961377, 6799337.1345314 ], [ 658700.9736961377, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799421.17784276 ], [ 658772.557494474, 6799421.17784276 ], [ 658772.557494474, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799430.268091854 ], [ 658687.9659901621, 6799430.268091854 ], [ 658687.9659901621, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799382.614641199 ], [ 658681.0780289881, 6799382.614641199 ], [ 658681.0780289881, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
