Api session event editor parametric remove
API Event to Remove existing Parametric
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID or multiple values in array [1, 2, 3]) | Parametric Design |
| 200 | Boolean (True when at least one item was removed) |
Example POST: https://engine.tygron.com/api/session/event/editorparametric/remove/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
