Api session event editor panel remove global
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Global
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Global
200 Boolean (Content was updated)
Example POST: https://engine.tygron.com/api/session/event/editorpanel/remove_global/?f=JSON&token=API_TOKEN
with content:
[ 7, [ 1, 2, 3 ] ]
