Api session event editor panel remove
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove existing Panel
0 REQUIRED (PANEL Integer ID or multiple values in array [1, 2, 3]) Panel
Example POST: https://engine.tygron.com/api/session/event/editorpanel/remove/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
