Api session event editor panel add
Revision as of 12:10, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new Panel
0 REQUIRED (Enumeration) PanelType EXCEL_PANEL, GLOBAL_PANEL, TEMPLATE_EXCEL_PANEL, TEMPLATE_TEXT_PANEL, TEXT_PANEL or WEB_PANEL
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorpanel/add/?f=JSON&token=API_TOKEN
with content:
[ "TEMPLATE_EXCEL_PANEL" ]
