Api session event editor netload set building
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Building
0 REQUIRED (NET_LOAD Integer ID) Net Load
1 REQUIRED (BUILDING Integer ID) Building
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/set_building/?f=JSON&token=API_TOKEN
with content:
[ 20, 22 ]
