Api session event editor netload remove node
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Node
0 REQUIRED (NET_LOAD Integer ID) Net Load
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/remove_node/?f=JSON&token=API_TOKEN
with content:
[ 92 ]
