Api session event editor netload remove address
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Address
0 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Load
1 REQUIRED (ADDRESSE Integer ID or multiple values in array [1, 2, 3]) Address
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/remove_address/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
