Api session event editor netload remove attribute
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove attribute from Net Load
0 REQUIRED (NET_LOAD Integer ID or multiple values in array [1, 2, 3]) Net Load
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/remove_attribute/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Text 1", "Text 2", "Text 3" ] ]
