Api session event editor netline remove attribute
Revision as of 12:09, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove the specified attributes for each specified Net Line
0 REQUIRED (NET_LINE Integer ID or multiple values in array [1, 2, 3]) Net Line IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attributes
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetline/remove_attribute/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Attribute 1", "Attribute 2", "Attribute 3" ] ]
