Api session event editor levee set use existing function
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Use Existing Function
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (true, false) Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorlevee/set_use_existing_function/?f=JSON&token=API_TOKEN
with content:
[ 19, true ]
