Api session event editor levee set angle degrees
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Angle Degrees
0 REQUIRED (LEVEE Integer ID) Levee
1 REQUIRED (Floating point number) Double
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorlevee/set_angle_degrees/?f=JSON&token=API_TOKEN
with content:
[ 39, 19 ]
