Api session event editor global remove
Revision as of 12:06, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove existing Global
0 REQUIRED (GLOBAL Integer ID or multiple values in array [1, 2, 3]) Global
Example POST: https://engine.tygron.com/api/session/event/editorglobal/remove/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
