Api session event editor geolink set mapping
Revision as of 12:06, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Map orginal Attribute name to a new name in the created feature.
0 REQUIRED (GEO_LINK Integer ID or multiple values in array [1, 2, 3]) CustomGeo Link IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Orginal Attribute Names
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) New Attribute Names
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorgeolink/set_mapping/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Orginal Attribute Name 1", "Orginal Attribute Name 2", "Orginal Attribute Name 3" ], [ "New Attribute Name 1", "New Attribute Name 2", "New Attribute Name 3" ] ]
