Api session event editor cinematic set keypoint description
Revision as of 12:05, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Keypoint Description
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic
1 REQUIRED (Integer number) Integer
2 REQUIRED (String) String
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_description/?f=JSON&token=API_TOKEN
with content:
[ 75, 84, "Text" ]
