Api session event editor building query
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Executes a single TQL query. Note: you can also use the session/query endpoint to execute multiple statements and get additional information on API usage.
0 REQUIRED (String) TQL Query Statement
1 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Value for update queries (optional)
200 Object (Object)
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/query/?f=JSON&token=API_TOKEN
with content:
[ "TQL Query Statement", "" ]
