Api session event editor building add underground
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add Underground
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/add_underground/?f=JSON&token=API_TOKEN
with content:
[ 29 ]
