Api session event editor area set relation
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Relation
0 REQUIRED (AREA Integer ID) Area
1 REQUIRED (Enumeration) Relation BORDER_A, BORDER_B, BUILDING, CONSTRUCTOR, DEMOLISHER, NETOWNER, OWNER, PARENT, PERMITTER, RECEIVER, RESULT_PARENT, SENDER or WEATHER
2 REQUIRED (Integer number) Integer
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorarea/set_relation/?f=JSON&token=API_TOKEN
with content:
[ 14, "RESULT_PARENT", 50 ]
