Api session event editor area generate water areas
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Generate Water Area
0 REQUIRED (Floating point number) Double
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorarea/generate_water_areas/?f=JSON&token=API_TOKEN
with content:
[ 29 ]
