Api session event editor clear map
Revision as of 12:03, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove all geospatial data of the Project, such as Building, Area, etc.
0 REQUIRED (true, false) Delete the map size and georeference too (false means deleting only the geodata) true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editor/clear_map/?f=JSON&token=API_TOKEN
with content:
[ false ]
