Api session event editor panel add answer event
API Event to Add Answer (Panel) Event
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/add_answer_event/?f=JSON&token=API_TOKEN
with content:
[ 81, 52, false ]
