TQL
TQL
The Tygron Query Language is a special-purpose programming language designed for obtaining spatial area information during a specific project session in the Tygron Engine. The primary reason for its introduction was to bridge the gap between the Tygron Engine and Microsoft Excel.
Queries
The main operation used in TQL is the query, which is performed with the declarative SELECT statement. A declarative statement tells the system which data is specifically required, after which the system will retrieve the data on it's 'own'. This is contrary to an imperative statement, where the system is told 'how' to obtain said data. A SELECT statement retrieves data from a running Tygron project session. The SELECT statements have no persistent effect on the project session itself.
Queries in TQL using the SELECT statement allow the user to describe the desired data, leaving the Tygron Engine responsible for planning, optimizing, and performing the physical operations necessary to produce the desired result as output.
A query includes a parameter to include in the final result, immediately following the SELECT keyword. Currently, one of the following result parameters can be chosen:
| Result Parameter | Description | Example |
FLOORSIZE
Floor size of buildings. | SELECT_FLOORSIZE_WHERE_CATEGORY_IS_OFFICES
LOTSIZE
Lot size of buildings. | SELECT_LOTSIZE_WHERE_CATEGORY_IS_OFFICES
UNITS
Amount of housing units. | SELECT_UNITS_WHERE_CATEGORY_IS_SOCIAL
DIKES
Surface space of constructed dikes or levees. | SELECT_DIKES_WHERE_ZONE_IS_1
Comparison Predicate
The SELECT and result parameter are followed by the WHERE statement. The WHERE statements includes a comparison predicate, which restricts the information taken into account by the query. The WHERE clause eliminates all information from the result set where the comparison predicate does not evaluate to True.
The comparison predicate consists of 0 or more clauses. Clauses consists of three parts;
- Clause Type
- Operator
- Value
Clauses
Some clauses are particular for constructions, others are applied to surface areas of constructions or dikes. The clause types and expected values currently supported are:
| Clause Type | Description | Value Type | Example |
CATEGORY
A construction belongs to the specific Function category | Function category | CATEGORY_IS_INDUSTRY
FUNCTION
A construction belongs to a specific Function | Function ID | FUNCTION_IS_621
DIKE
Surface area lies (partly) within a particular type of Dike (or Levee) | Dike ID | DIKE_IS_0
MAP
A construction or dike is present in the specified map or view. Also see Simulation Type | CURRENT or MAQUETTE | MAP_IS_MAQUETTE
STAKEHOLDER
A construction or surface area is owned by a specific Stakeholder | Stakeholder ID | STAKEHOLDER_IS_7
STAKEHOLDERTYPE
A construction or surface area is owned by stakeholders of a specific Stakeholder Type | Stakeholder Type | STAKEHOLDERTYPE_IS_COMPANY
STATE
A construction resides in the specified State | State Type | STATE_IS_PENDING_CONSTRUCTION
TERRAIN
Surface area lies (partly) within a specific Terrain | Terrain ID | TERRAIN_IS_1
TERRAINTYPE
Surface area lies (partly) within terrains with a specific Type of Terrain | Terrain Type | TERRAIN_IS_1
ZONE
Surface area lies (partly) within a specific Zone | Zone ID | ZONE_IS_25
Operators
TQL clausses currently support the following Operators:
| Operator | Description | Example |
IS
Equal to | CATEGORY_IS_OFFICES
Simulation Type
Depending on the Simulation Type, the map parameter is named as followed in the Query Tool:
MAQUETTE
| Planning | ORIGINAL
PLANNED
| Timeline | TODAY
MODEL
State
During the game sessions, constructions go from one phase to another. For example; from being planned, to being permitted, to being constructed, to being ready. The current available states are:
| State | Explanation |
CONSTRUCTING
Construction is being constructed. |
CONSTRUCTION_APPROVED
Construction is approved. |
CONSTRUCTION_DENIED
Construction is denied. |
DEMOLISH_APPROVED
Demolition is approved. |
DEMOLISH_DENIED
Demolition is denied. |
DEMOLITION_FINISHED
Demolition is finished. |
DEMOLISHING
Construction is being demolished. |
NOTHING
Construction does not exist. |
Construction is waiting for the date to be constructed. |
PENDING_DEMOLISHING
Construction is waiting for the date to be demolished. |
PENDING_UPGRADE
Construction is waiting for the date to be upgraded. |
READY
Construction is done constructing. |
REQUEST_CONSTRUCTION_APPROVAL
Request is send to ask construction approval. |
REQUEST_DEMOLISH_APPROVAL
Request is send to ask demolition approval. |
REQUEST_ZONING_APPROVAL
Request is send to ask zoning approval. |
WAITING_FOR_DATE
Waiting to receive a date on which to start construction. |
WAITING_FOR_DEMOLISH_DATE
Waiting to receive a date on which to start demolition. |
Query Construction
In order to make it easier to construct queries, a tool has been developed to create queries in the editor, which can then be copied and used elsewhere. This tool is known as the Query Tool and more information can be found on its own page.
TQL Uses
TQL is currently used to communicate with Microsoft Excel, using the Excel Indicator.
