Api session event editor indicator set target
API Event to Set a target value of an Indicator for a Sceanrio. A target index value is required.
0 REQUIRED (SCENARIO Integer ID) Scenario ID
1 REQUIRED (INDICATOR Integer ID) Indicator ID
2 REQUIRED (Integer number) Target index
3 REQUIRED (Floating point number) Target value
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_target/?f=JSON&token=API_TOKEN
with content:
[ 48, 67, 26, 54 ]
