Api session event editor area set attribute
API Event to Set Area attribute value
| 0 | REQUIRED | (AREA Integer ID or multiple values in array [1, 2, 3]) | Area | |
| 1 | REQUIRED | (String) | Attribute Name | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Attribute Values | |
| 200 | Boolean (Content was updated) |
Example POST: https://engine.tygron.com/api/session/event/editorarea/set_attribute/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]
