Api session event editor unitdataoverride set active
API Event to Set Unit Data Override active
0 REQUIRED (UNIT_DATA_OVERRIDE Integer ID or multiple values in array [1, 2, 3]) Unit Data Override
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Boolean[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorunitdataoverride/set_active/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ] ]
