Api session event editor parametric save as measure
API Event to Save As Measure
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID) | Parametric Design | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 2 | REQUIRED | (FunctionType or multiple values in array [a, b, c]) | FunctionType[] | |
| 3 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] | |
| 4 | REQUIRED | (MultiPolygon or multiple values in array [a, b, c]) | MultiPolygon[][] |
| 200 | Integer (Integer) |
Example POST: https://engine.tygron.com/api/session/event/editorparametric/save_as_measure/?f=JSON&token=API_TOKEN
with content:
[ 32, 4, [ "ROAD", "SIDEWALK", "GARDEN" ], [ 1, 2, 3 ], [ [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799379.774055493 ], [ 658651.9816308668, 6799379.774055493 ], [ 658651.9816308668, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799430.411015273 ], [ 658707.5335818208, 6799430.411015273 ], [ 658707.5335818208, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799397.8521511275 ], [ 658793.8661600254, 6799397.8521511275 ], [ 658793.8661600254, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799312.175231103 ], [ 658708.4252325363, 6799312.175231103 ], [ 658708.4252325363, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799446.114741311 ], [ 658746.1263036828, 6799446.114741311 ], [ 658746.1263036828, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799395.66120917 ], [ 658788.5617315428, 6799395.66120917 ], [ 658788.5617315428, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
