Api session event editor overlay set overlay area
API Event to Add or remove specified Area to or from a specified AREAS Overlay. Unincluded Area which are already related to the Overlay will remain related. Unincluded Area which are not related to the Overlay will remain unrelated.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to an AREAS Overlay)
1 REQUIRED (AREA Integer ID or multiple values in array [1, 2, 3]) Array of Area IDs
2 REQUIRED (true, false) Should be added to the Overlay (false removes the Area from the Overlay) true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_area/?f=JSON&token=API_TOKEN
with content:
[ 76, [ 1, 2, 3 ], false ]
