Api session event editor indicator set update timing
API Event to Set Update Timing
0 REQUIRED (INDICATOR Integer ID or multiple values in array [1, 2, 3]) Indicator
1 REQUIRED (Timing or multiple values in array [a, b, c]) Timing[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_update_timing/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "AFTER", "AFTER", "BEFORE" ] ]
