Api session event editor geotiff add ascii
API Event to Add new GeoTIFF Item with provided ASCII file. For files larger than 2GB, use the Stream API or Web URL.
| 0 | REQUIRED | (String) | GeoTIFF Name | |
| 1 | REQUIRED | (byte or multiple values in array [a, b, c]) | ASCII File bytes (< 2GB) | |
| 2 | REQUIRED | (String) | Uploader | |
| 3 | REQUIRED | (String) | CRS |
| 200 | Integer (GeoTIFF ID) |
Example POST: https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii/?f=JSON&token=API_TOKEN
with content:
[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "CRS" ]
