Api session event editor parametric save as measure
API Event to Save As Measure
0 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Design
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
2 REQUIRED (FunctionType or multiple values in array [a, b, c]) FunctionType[]
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
4 REQUIRED (MultiPolygon or multiple values in array [a, b, c]) MultiPolygon[][]
200 Integer (Integer)
Example POST: https://engine.tygron.com/api/session/event/editorparametric/save_as_measure/?f=JSON&token=API_TOKEN
with content:
[ 69, 37, [ "ROAD", "PUBLIC_GREEN", "PARKING" ], [ 1, 2, 3 ], [ [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799365.902461736 ], [ 658766.0122260158, 6799365.902461736 ], [ 658766.0122260158, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799317.932689102 ], [ 658699.5623218721, 6799317.932689102 ], [ 658699.5623218721, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799365.360006733 ], [ 658756.5532574053, 6799365.360006733 ], [ 658756.5532574053, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799436.842571742 ], [ 658746.2107587596, 6799436.842571742 ], [ 658746.2107587596, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799318.022015003 ], [ 658676.1926276177, 6799318.022015003 ], [ 658676.1926276177, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799301.457762352 ], [ 658655.0479998119, 6799301.457762352 ], [ 658655.0479998119, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
