Api session event editor parametric apply
API Event to Apply
| 0 | REQUIRED | (PARAMETRIC_DESIGN Integer ID) | Parametric Design | |
| 1 | REQUIRED | (STAKEHOLDER Integer ID) | Stakeholder | |
| 2 | REQUIRED | (FunctionType or multiple values in array [a, b, c]) | FunctionType[] | |
| 3 | REQUIRED | (Integer number or multiple values in array [1, 2, 3]) | Integer[] | |
| 4 | REQUIRED | (MultiPolygon or multiple values in array [a, b, c]) | MultiPolygon[][] |
Example POST: https://engine.tygron.com/api/session/event/editorparametric/apply/?f=JSON&token=API_TOKEN
with content:
[ 20, 5, [ "GARDEN", "REMAINDER", "BUILDING" ], [ 1, 2, 3 ], [ [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799323.33447148 ], [ 658697.345376104, 6799323.33447148 ], [ 658697.345376104, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799406.16604228 ], [ 658771.6560989419, 6799406.16604228 ], [ 658771.6560989419, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799409.352575987 ], [ 658792.5895890555, 6799409.352575987 ], [ 658792.5895890555, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799427.166004629 ], [ 658792.4060616769, 6799427.166004629 ], [ 658792.4060616769, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799341.482277875 ], [ 658741.7557534542, 6799341.482277875 ], [ 658741.7557534542, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799316.677254331 ], [ 658732.683329234, 6799316.677254331 ], [ 658732.683329234, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
