Api session event editor panel remove answer event
API Event to Remove Answer (Panel) Event
| 0 | REQUIRED | (PANEL Integer ID) | Panel | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (true, false) | Boolean | true or false |
| 3 | REQUIRED | (Integer number) | Integer |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/?f=JSON&token=API_TOKEN
with content:
[ 26, 32, true, 21 ]
