Api session event editor overlay add result child
API Event to Add a specified result type as a child Overlay to a specified grid Overlay. The child Overlay's result will be based on the parent's calculation, allowing you to get multiple types of results from the same calculation.
| 0 | REQUIRED | (OVERLAY Integer ID) | Overlay ID (must relate to a grid Overlay with result types) | |
| 1 | REQUIRED | (String) | Result type for new child Overlay (must be a valid result for the parent Overlay type) |
| 200 | Integer (Overlay ID) |
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/add_result_child/?f=JSON&token=API_TOKEN
with content:
[ 47, "Result type for new child Overlay" ]
