Api session event editor netload generate loads
API Event to Generate Loads
| 0 | REQUIRED | (Enumeration) | NetType | ELECTRICITY, GAS, HEAT, INTERNET or SEWER |
| 1 | REQUIRED | (MultiPolygon with crs: EPSG:3857) | MultiPolygon | |
| 2 | REQUIRED | (Category or multiple values in array [a, b, c]) | Category[] | |
| 3 | REQUIRED | (Integer number) | Integer | |
| 4 | REQUIRED | (Integer number) | Integer | |
| 5 | REQUIRED | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Stakeholder | |
| 6 | REQUIRED | (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) | Stakeholder | |
| 7 | REQUIRED | (true, false) | Boolean | true or false |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editornetload/generate_loads/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ "HEAT", {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799398.073031891 ], [ 658770.2593419013, 6799398.073031891 ], [ 658770.2593419013, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "OTHER", "BRIDGE", "INDUSTRY" ], 51, 76, [ 1, 2, 3 ], [ 1, 2, 3 ], false ]
