Api session event editor netload import
API Event to Import multiple Net Loads
0 REQUIRED (GeometryCollection with crs: EPSG:3857) GeometryCollection
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
2 REQUIRED (NetType or multiple values in array [a, b, c]) NetType[]
3 REQUIRED (TimeState or multiple values in array [a, b, c]) TimeState[]
4 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
5 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
6 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) double[][]
7 REQUIRED (Integer number) Integer
8 REQUIRED (Floating point number) Double
9 REQUIRED (Floating point number) Double
10 REQUIRED (SOURCE Integer ID) Source
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetload/import/?crs=3857&f=JSON&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799368.596872012 ], [ 658778.8169149797, 6799368.596872012 ], [ 658778.8169149797, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799402.463038329 ], [ 658638.5532736429, 6799402.463038329 ], [ 658638.5532736429, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799319.431740196 ], [ 658797.9135071712, 6799319.431740196 ], [ 658797.9135071712, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Text 1", "Text 2", "Text 3" ], [ "ELECTRICITY", "GAS", "INTERNET" ], [ "REQUEST_DEMOLISH_ZONING_APPROVAL", "REQUEST_PLOT_OWNER_APPROVAL", "NOTHING" ], [ "Text 1", "Text 2", "Text 3" ], [ "Text 1", "Text 2", "Text 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], 51, 97, 44, 71 ]
