Api session event editor netline move and insert
API Event to Place an existing Node at a new location and insert it in an existing Net Line, potentially splitting the Net Line into two parts. Also specify at what distance the new Nodes are merged with existing Nodes.
| 0 | REQUIRED | (NET_NODE Integer ID) | Net Node ID | |
| 1 | REQUIRED | (NET_LINE Integer ID) | Net Line ID | |
| 2 | REQUIRED | (Point 3D with crs: EPSG:3857) | New Node Point | |
| 3 | OPTIONAL | (Floating point number) | Node merge distance (optional, default: 1.0m) |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editornetline/move_and_insert/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ 61, 92, {
"type" : "Point",
"coordinates" : [ 658666.8132416758, 6799412.785978128, -1.84 ]
}, 1.0 ]
