Api session event editor measure set cost
API Event to Set the Cost of a Measure of a particular Cost type (construction, demolition) and wether it is fixed or Cost per cubic meter.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 1 | REQUIRED | (Enumeration) | Cost Type | CONSTRUCTION |
| 2 | REQUIRED | (Floating point number) | Cost in valuata | |
| 3 | REQUIRED | (true, false) | Fixed (if false, Cost per cubic meter) | true or false |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_cost/?f=JSON&token=API_TOKEN
with content:
[ 9, "CONSTRUCTION", 57, false ]
