Api session event editor measure remove event
API Event to Add a specific event of a Measure for a specific Action Type.
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Server Side (false = Client Side)
2 REQUIRED (ActionType or multiple values in array [a, b, c]) Action Type
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Event ID
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/remove_event/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN" ], [ 1, 2, 3 ] ]
