Api session event editor indicator set update timing
API Event to Set Update Timing
| 0 | REQUIRED | (INDICATOR Integer ID or multiple values in array [1, 2, 3]) | Indicator | |
| 1 | REQUIRED | (Timing or multiple values in array [a, b, c]) | Timing[] |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_update_timing/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "BEFORE", "AFTER", "AFTER" ] ]
