Api session event editor indicator set target
API Event to Set a target value of an Indicator for a Sceanrio. A target index value is required.
| 0 | REQUIRED | (SCENARIO Integer ID) | Scenario ID | |
| 1 | REQUIRED | (INDICATOR Integer ID) | Indicator ID | |
| 2 | REQUIRED | (Integer number) | Target index | |
| 3 | REQUIRED | (Floating point number) | Target value |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorindicator/set_target/?f=JSON&token=API_TOKEN
with content:
[ 45, 76, 77, 49 ]
