Right Panel
Revision as of 12:04, 14 August 2015 by Joris@tygron.com (talk | contribs)
Right panel
File:Editor right panel.jpg
The right panel allows you to change properties of selected items in the left panel.
The right panel, on the right side of the screen, provides access to properties currently selected in the left panel. The "Finance Municipality" item is currently selected in the left panel. Its properties can be changed from within the right panel.
Indicator type
File:Editor right panel indicator type.jpg
Indicator Type
The indicator type describes the type of an indicator. For more information on indicator types see: Indicator types
Stakeholder
File:Editor right panel indicator stakeholder.jpg
Stakeholder
The stakeholder this indicator is linked to. This link only applies to stakeholder specific indicators, Budget and Building
Name
File:Editor right panel indicator name.jpg
Name
The name of the indicator. This is the name which will appear in the indicator description. The name can be altered by changing it in the name field.
Short Name
File:Editor right panel indicator shortname.jpg
Short Name
The short name of the indicator, which will be used in instances in game with limited space, This occurs in places such as the top bar and in drop down lists. The short name can be altered by changing it in the name field.
Color
File:Editor right panel indicator color.jpg
Color
The color of the indicator. This color is used in the indicator panel, the progress panel, and in the Assignment Screen. The color can be changed by pressing the dropdown-list and selecting a different color
Active
File:Editor right panel indicator active.jpg
Name
The status of the indicator. Whether the current status of the indicator is active or inactive. If an indicator is active, it will appear for the stakeholder.
Description
File:Editor right panel indicator description.jpg
Description
The description of the indicator. This description will appear in the indicator panel. A good description will help users to take the necessary and correct actions. You can change the description by altering the text in the text area.
