Api session event editor geotiff add ascii
Revision as of 08:14, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new GeoTIFF Item with provided ASCII file. For files larger than 2GB, use the Stream API or Web URL.
0 REQUIRED (String) GeoTIFF Name
1 REQUIRED (byte or multiple values in array [a, b, c]) ASCII File bytes (< 2GB)
2 REQUIRED (String) Uploader
3 REQUIRED (String) CRS
200 Integer (GeoTIFF ID)
Example POST: https://engine.tygron.com/api/session/event/editorgeotiff/add_ascii/?f=HTML&token=API_TOKEN
with content:
[ "GeoTIFF Name", [ 1, 2, 3 ], "Uploader", "CRS" ]
