Api session event editor parametric apply
Revision as of 07:54, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Apply
0 REQUIRED (PARAMETRIC_DESIGN Integer ID) Parametric Design
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
2 REQUIRED (FunctionType or multiple values in array [a, b, c]) FunctionType[]
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
4 REQUIRED (MultiPolygon or multiple values in array [a, b, c]) MultiPolygon[][]
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorparametric/apply/?f=HTML&token=API_TOKEN
with content:
[ 93, 77, [ "REMAINDER", "PUBLIC_GREEN", "ROAD" ], [ 1, 2, 3 ], [ [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799404.030318305 ], [ 658741.8515774837, 6799404.030318305 ], [ 658741.8515774837, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799375.488004963 ], [ 658732.6069948375, 6799375.488004963 ], [ 658732.6069948375, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799428.224936887 ], [ 658765.8059607319, 6799428.224936887 ], [ 658765.8059607319, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799358.090463542 ], [ 658669.3339008935, 6799358.090463542 ], [ 658669.3339008935, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799450.134471306 ], [ 658639.9792651333, 6799450.134471306 ], [ 658639.9792651333, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799326.836049712 ], [ 658675.6030662158, 6799326.836049712 ], [ 658675.6030662158, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
