Api session event editor panel remove answer event
Revision as of 07:54, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Answer (Panel) Event
0 REQUIRED (PANEL Integer ID) Panel
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
3 REQUIRED (Integer number) Integer
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorpanel/remove_answer_event/?f=HTML&token=API_TOKEN
with content:
[ 32, 61, true, 52 ]
